Wheel and Tire Overview
troutspinner
SE Pennsylvania
The Mods have stickied this thread so that users can share their results with aftermarket rim, tires and lifts. Members please share your results and I will add them to this top thread for a comprehensive post.
Note: I am a wheel and tire rookie! If you see an error in my post, or something I need to add, please let me know.
2019 1500 OEM Rim Sizes
OEM Rim Size
OEM Bolt Pattern
OEM Thread Size
OEM Center Bore
OEM Offset
OEM Backspace
18" x 8"
6x139.7mm
M14 x 1.5mm
77.8mm
19.05mm
5.25"
20" x 9"
6x139.7mm
M14 x 1.5mm
77.8mm
19.05mm
5.75"
22" x 9"
6x139.7mm
M14 x 1.5mm
77.8mm
19.05mm
5.75"
2019 1500 OEM Tire Sizes
Tire Size
Tire Diameter
Tire Width
Tire Sidewall
OEM Rim Width
275/65R18
32.1"
10.8"
7"
8"
275/70R18
33.2"
10.8"
7.6"
8"
275/55R20
31.9"
10.8"
6"
9"
285/45r22
32.1"
11.2"
5"
9"
Aftermarket Rim Sizes
Looking for info from members. Rim Size, Offset, Distance it sits past stock, clearance issues?
Aftermarket Tire Sizes
Maximum Tire Size @ OEM Height
Maximum Tire Size - Rebel or Off Road Package @ OEM Height
Maximum Tire Size - Air Ride Equipped @ OEM Height
Maximum Tire Size - Air Ride Equipped (Rebel or Off Road Package) @ OEM Height
Maximum Tire Size with 2" Level
Maximum Tire Size with Mopar 2" Lift
Maximum Tire Size with Rough Country 3.5" Lift
Other Lifts & Sizes
PorBoy
Millville NJ
I totally agree and hopefully doing so will clear up a lot of my clutter lol.
edrclark
Moderator
Site Supporter & Order Tracking
Portland, Oregon
Mods, can you create and stickey a wheel and tire thread. Something like stock 18” wheels have a +19.05 offset / 275/65/R18 Tires.
20’s etc.
22’s etc.
1” lift you can go up X” on tire size
2” lift you can up X” tire size
3.5”, etc.
Maybe have members contribute their changes and success and then add that info to the top post?
I see MANY questions all over the forum about tires and rims, I’ve made some myself and it would be nice to have a comprehensive stickied thread.
You are stuck
troutspinner
SE Pennsylvania
Please add max tire size for Air Ride with Off Road Package.
I added to the top post....of course looking for info from members.
I have the ORP on my truck (non air) so I know I can get a 33" under there without issue (stock is 32"). Someone posted somewhere (sorry, can't remember who) that they put the 2" Mopar lift on their Rebel and were able to squeeze 35's on it but did say it was very close for rubbing. Since a 2" Mopar Lift nets you 1" on the ORP or Rebel, this leads me to believe that a safe recommendation for a stock Rebel or ORP is 33" and YMMV with 34" depending on the width of the 34.
blownout1500
Anyone know the minimum wheel diameter for the 2019’s?
Almost pulled the trigger on 17x8.5” method NV’s (plenty of 4th gen’s run them) but a quick check behind my stock 18x8 wheels paused that plan: only about 1/8” clearance at calipers(!).
blownout1500
OEM Rim Size
OEM Bolt Pattern
OEM Thread Size
OEM Center Bore
OEM Offset
OEM Backspace
18" x 8"
6x139.7mm
M14 x 1.5mm
77.8mm
19.05mm
5.25"
20" x 9"
6x139.7mm
M14 x 1.5mm
77.8mm
19.05mm
5.75"
22" x 9"
6x139.7mm
M14 x 1.5mm
77.8mm
19.05mm
5.75"
Tire Size
Tire Diameter
Tire Width
Tire Sidewall
OEM Rim Width
275/65R18
32.1"
10.8"
7"
8"
275/70R18
33.2"
10.8"
7.6"
8"
275/55R20
31.9"
10.8"
6"
9"
285/45r22
32.1"
11.2"
5"
9"
Other Lifts & Sizes
Looks like aftermarket 18”s might not even fit:
https://www.ramforum.com/threads/psa-18-wheels-wont-fit-on-the-limited.123563/
Of course I found the info AFTER I ordered 18” wheels & tires (deep breath).
troutspinner
SE Pennsylvania
blownout1500
I’ve talked to a couple people who sell rims and am being told that it comes down to the offset with 18s. Like Fuel Couplers for example I was told a 1 offset works but a 20 will not. Please let us know your results.
Well that’s some good news I guess. Ordered 18x9 -12os so in theory should be safe. Will report back when the wheels come in.
Billet1500 4x4
California
I have a set of 18x9 -12 offset fuels with 33x12.50 ridge grapplers from my old truck so I put them on to see if they would fit. The tire shop would have to be very careful balancing them as you can see the strap weights hit the caliper. They fit and do not rub on a stock 4x4 without the offroad package.
Billet1500 4x4
California
I'd look for a shop that can do what they call a 0 gram balance. The wheel weight they use for balancing is a flexible continuous strip that they cut to length depending on how many grams they need to balance the wheel as opposed to the individual 1/4 oz weight that most shops use. Its made by 3M and they have a lot of options for balancing here is a link to a you tube video about it.
, gm balances their factory wheels with it and there is one shop in town where I live that I know for sure has it. Make sure they test fit and rotate the wheel before driving off. It's probably going to be tough to get a 2 plane balance because they wont be able to put any weight along about the outer 2 inches of the interior edge. Depending on how aggressive the tires they may require quite a bit of weight to balance out. I didn't look at the clearance between the knuckle where the upper ball joint mounts and the lip of the rim but it may possible to use some old school lip weights or the 3M flange weight. It's really going to boil down to finding the right shop to get it dialed in.
Billet1500 4x4
California
OEM Rim Size
OEM Bolt Pattern
OEM Thread Size
OEM Center Bore
OEM Offset
OEM Backspace
18" x 8"
6x139.7mm
M14 x 1.5mm
77.8mm
19.05mm
5.25"
20" x 9"
6x139.7mm
M14 x 1.5mm
77.8mm
19.05mm
5.75"
22" x 9"
6x139.7mm
M14 x 1.5mm
77.8mm
19.05mm
5.75"
Tire Size
Tire Diameter
Tire Width
Tire Sidewall
OEM Rim Width
275/65R18
32.1"
10.8"
7"
8"
275/70R18
33.2"
10.8"
7.6"
8"
275/55R20
31.9"
10.8"
6"
9"
285/45r22
32.1"
11.2"
5"
9"
Other Lifts & Sizes
For anyone thinking about keeping the factory wheels and adding wheels spacers to push the stance out a bit.
The factory stud length is 40mm or about 1-9/16" but ram did something fantastic at least on the 20x9 on my truck and they cast pockets between the stud holes that are 1-1/4" deep. Effectively allowing you to use spacers that are shorter than the studs and the remaining stud that sticks out past the spacer will nest nicely into these pockets. I'm looking at going this route because these factory 20's are so light about the same or less than most 18" after market wheels and depending on tire size a lot people running the 34 and 35 inch tires are adding 30 lbs of tire weight alone, after market 20's probably another 10 lb's. I weighed the factory 20x9 with the 275 55 20 at 72.3 lbs I'd be willing to be most of the aftermarket setups are pushing 110 lbs each. That's a lot of additional inertia to get moving as well as unsprung weight loading the tie rod ends and ball joints which gets even worse when running more negative offset. Just my 2 cents but the absolute best tire choice is the P rated 305 55 20 ridge grappler at 51.5 lbs on the factory 20 adds about 10-12 lbs per corner. Even with the additional weight of the wheel spacer the effect won't be as bad because the weight is concentrated near the axis of rotation.
blownout1500
Good looking out thank you (y). Had the self-balancing beads in a set of ko2’s on my old taco. They’d solve this clearance issue but I think they might have also been the source of some highway speed vibration I was having in the taco (they clump up if there’s moisture in the tire).
blownout1500
Those bumps on the outer edge of the caliper look like they might be extremely easy to delete. Just saying.
John813
Would be curious if anyone had the weights of the stock wheels and tires.
18s: Base and Rebel
20's:
22's:
etc
Naughtyca
probably best to also add online websites to buy wheels like customoffset and elementwheels.com will actually gives you a thumbs up and tell you if the tire and wheel you chose will fit
Naughtyca
i also read from the forum that 24" tire, 24x10 with +25 offset and tire size of 305/35/r24 total wheel diameter 32.4 will fit stock no leveling or lift
