How to: modify wheel wells for larger tires/Negative offsets
Chris VB
Ontario Canada
I gotta say, I just installed 37x12.5R22 -44 offset, and no amount of heat gun will get these things to fit without rubbing. I am on a 5 inch RC air lift + custom links giving me another 1-1.5".
I had to use custom Air Links so I could get the already 5" lift even higher, I'm in about Off-road 2 setting (with custom links). I had to trim the front plastic valance, I had to heat gun and zip tie the inner liner towards the back, and I had to trim the inside of the bushwhacker fenders but even then the tires were rubbing on the metal tab. I had to grind about 3/8"-1/2" off to get them to fit without rubbing. With all this said I have about 1/4" clearance on all sides, if I lower the air suspension at all I won't be able to make full radius turns.
I have 37x13.5 and they wouldn’t fit on a 6” suspension lift I needed another 2” daystar lift to clear completely. No rubbing at all. Minor valence and liner trim with tie back. No trim on bushwhackers, clears by 3/8” :)
Chris VB
Ontario Canada
Also your truck looks great!
Whitby, Ontario
Bringing this back to life. I noticed that some of you have taken the bending back method rather than cutting. I seen some saying the paint cracked when bending back.
Wouldn't it be more advisable to cut it off so you only have one narrow exposed metal piece that needs to be painted? Wouldn't the cracking of the paint cause more exposed bare metal?
Anyone got close up pictures of the tab bent rather than cut?
I am getting prepped to do this in the next little bit once I get my spacers. Hoping I won't have to do anything but probably not as it was close with 1.5" , I can only assume 2" will put me even closer.
TPA-RAM
Late to the party...but installed 2" leveling kit and 295/65R20's AT3's (35.1x11.5) on stock 2020 Laramie wheels. Had slight rub on dealer installed RAM splashguards under full turn. Minor plastic trimming on splashguard and spalshshield did the trick. No heating/bending plastic req'd.
Do you have some pics of what and how you trimmed the plastics?
hardluck
will a 20x10 -19 offset with a 35/12.50R20 fit on a 2020 ram 1500 4wd with a 2 inch leveling strut?
mriley8683
Snapped some pictures while modifying the wheel wells today to fit my 35x12.50x20 on a 20x10 -18 offset.
Lift kit is a ReadyLift 3.5 SST
A lot of people ask do they Rub? Answer is Yes, solution is easy since it’s minimal labor.
Tools needed:
Wet towel
8mm socket
Grinder
Spray paint
Heatgun
2 Zip ties
Cold brew of choice!
Begin with finding affected areas, for me it was the Molding on rear of fenders, remove the 8mm bolt and the push in fastener in wheel well. Under the molding there are 2 sliding clips so give the piece a tug outward and should slide right out.
Under the wheel well liner there is a small Metal extension used solely for the retainer clip, this is causing a clearance issue, so I took my grinder and removed it,
I then drilled a small pilot hole to secure a zip tie to to hold the plastic liner back.
Once done drilling and removing excess sheetmetal apply spray paint of choice to avoid future oxidation.
I then proceeded to heat up the plastic liner in the affected area (Clean spot in picture below) as I would heat it up and it would become plyable I then massaged the area with a wet towel in order to mold it back and out of the way giving me more clearance. Move the material around slowly don't heat the area up to much to fast or you can melt it, apply even heat and cool towel pressure will allow you to shape it.
Next item to mold was the plastic trim, I heated the inside area to avoid messing with the finish on it, the lower channel is a bit to wide, so by heating it up and again applying pressure with the wet towel I was able to give myself the play needed to clear the tire.
Once installed here is the final look, no one would know the difference and you don't have to chop up your fender liners.
I also had a little rubbing happening on the front part of the fenders, right on the line (marked with square) so I heated this section up evenly and applied pressure again with a wet towel (Cause its hot, and it cools it down into the shape you want to hold) did this process for a few minutes fine tunning moving the material, letting it cool getting in the truck and turning the wheel all the way and listen for the rub. Once you stop hearing the rub you've completed the project.
Enjoy your Beer and Rub free ride...
Cheers!
Just ordered my kit today and trying to decide if 35x11.5 would fit any better then the 35x12.5’s… I have fuel rebel 20x10 -18 wheels so wondering if you think the 11.5 would be the same if not better or somehow worse? I’m definitely ok with the trimming you outlined. Thx in advance.
Eeram6
Wow, did this mod today and completely eliminates the rubbing I had at full turn. My plan was to install the Daystar spacer and make a link. I’m thinking I don’t need either now. The truck is perfect at normal height. 22x12 -40 on 33/12.5/22. I’m going to ride it like this for a week and decide if I want to proceed with the other steps or not. View attachment 24861
Any run after all?
Stillhetfield
Elizabethtown PA
Can anybody tell me with using this technique. Would I have any problem running. 20x9 -12 offset wheels with 35x11.50x20 Mopar 2-in lift plus off-road group total 3-in lift. Also would this work with factory flares
Stillhetfield
Elizabethtown PA
Works the same way. But, instead of cutting off the tab just bend it up. Then you can drill a hole on the new vertical surface and reuse the body clip to secure the flare and spat.
Do the fender flares have to be removed before doing this. Thanks for any help Happy Father's Day
mriley8683
Just got mine back. Thx to all in here as I love the way this turned out. 2019 1500 with no air ride and no off road package. 20x10 -18 fuel rebels and apparently new version of the ready lift 3.5 kit with 35x11.5 ridge grapplers. Haven’t done the trimming yet and incredibly minor rub in the wheel well plastic that the heat gun would fix. After there will be 100% no rub since the only rub now is full trim going off a lip on my driveway.
Stillhetfield
Elizabethtown PA
Truck looks great man !!! I want to do this same exact setup with off-road package and 2-in Mopar lift which gets me to 3" but I'm afraid I'll hit wheel wells or metal I can't make a final decision which offset to go with.
D3vans
Central Jersey
This is what I ended up with
2in Rough Country leveling kit
285/70R18 Nitto Ridge Grapplers
Did you even have to modify the wheel well? It looks like those slipped right in there! I am thinking about staying Falken AT3Ws but the LT285/75R18 on the stock wheel (same as yours). They are about an inch or two in both directions...
Blackmer18
Anyone know the name or part number of these plastic pieces? I'm going to do some trimming and want to have back up on hand.... I ordered what I thought was the part from Mopar and it's not correct... I ordered the Front left and right Fender Spats and that's not the correct part....
RLee276
This is very detailed, you think this would work with my 22inch stock wheels? I really want some 35's
I have a 2020 1500 bighorn on a 2.5 level lift and Fox shocks. 295/65R20 ridge grapplers . The measure 35 inches. Very slight rubbing in reverse when when cranking the steering wheel as far as it will go. No trimming.
BowersFJ
Did mine this weekend . . . Hot air on the front side . . . Straighten and bend up method on the back . . . Glad I ordered a few of the fasteners . . . The ones that hold the spats on are pretty brittle . . . Stock suspension, no ORG, 305/55R20 on 20"X10"-18 wheels . . . No rubbing at all . . . Now for 2" Readylift in the front, 1" Motofab with Hellwig in the rear
vadedram
Has anyone done any more metal trimming than just the tab? As in maybe part of the pinch weld, maybe going back as far as one of those bolts at the bottom. On my 4th gen 2500 I did some pinch weld trimming for 37s. So was just wanting to see if anyone has done more than just the tab.....
I have RC 3.5 lift, and am about to put on TRX wheels and 305/70R18 Yokahoma Geolander MTs (basically almost the same size as the factory TRX tires. I have seen most of the threads from people installing the TRX wheels/tires on with 1.5" spacers and it seems to be fine with the normal tab mod that this thread is mostly about. However, I have 2" spacers right now with current setup. I know maybe one person did it with 2" , but anyways, i just wanted to know incase i need to trim back the pinch weld too.
