- Jul 25, 2020
If you are going with hub centric spacers, the 78.1 bore will not work without grinding/maxhining down the hub ring on the spacer where the wheel sits. And for my, the Coyote spacers had the same issue because they werent the correct huh bore size for the factory Built to Serve wheels.Bringin it back again…
So I’ve decided to keep my trucks suspension stock, putting KO2’s (275/60/20’s) on my Ram Sports stock 20’s and adding 1.5” spacers.
Shop mounting them specializes in trucks and lift kits etc.. here in Canada it would seem they don’t have access to BORA or coyote. They suggested a set for Chevy with the 78.1 bore.. I don’t want to bring up any old grudge matches but should I go with the product they’re offering or should I go with an Amazon product that’s maybe half the price but proper 77.8 bore.. and just hope the quality is good and there’s no issues?
Buy the Bora spacers yourself and install them yourself. No need to pay a shop to install wheel spacers.
If this specialty shop is recommending using Chevy spacers, I would not use them as they obviously dont know what they are doing
