- Jul 25, 2020
I consider myself to be a pretty decent shade tree mechanic. There really isn't much I can't/won't do. Have rebuilt the motor in my Dakota R/T multiple times, rebuilt my 1966 poly 318, and a Dodge Spirit R/T DOHC engine. But my stepsons truck, with a 305 Chevy, is absolutely kicking my ***. To start with, the Chevy LT engines you have to pull distributor to remove intake manifold. Okay, I took a pic to make sure it gets back in correctly. Then you have to remove power steering pump pulley in order to get accessory bracket off. And the absolute last straw that has been kicking my *** all f-in day long is I cant get the rear passenger side of the intake manifold to seal up and leaks coolant when I try to fill. Have had the intake manifold off and on 5 or six times today. Been through an entire tube of the right stuff RTV and two different gasket sets and it still MFing leaks coolant. I give up. Have spent two full days on what was supposed to be a simple learning experience for my step-son, on basic mechanics and replacing an intake manifold gasket.
