Looking for spare fuse slot
frisby5
I will.probably just tap into f60 . Then maybe later run a switch into the cabin. I dont want to make this overly complicated its not critical im just changing grilles for the look ,they just happen to have lights lol
theblet
I’d prob do the same. Sucks that it’s a critical fuse, but no one has had issues yet. I’d prob keep some spares in the truck just in case
frisby5
I tapped into fuse F44 trailer ind light ? It works when truck is turned to mar . I dont have a trailer but there is a 10 amp fuse in the slot. So i put in a add a fuse, grill lights are working now. Heres a picture ,changed the grill and lights. Figured i would change the halogens since i had everything apart anyways lol.
frisby5
My fuse box has f44 says trailer camera. I’ll have to take a looksie and see if it has a fuse or not. Sounds like it worked out for you tho.
Yes Its the trailer camera. I didnt want to tie into anything vital like the ecm or fuel pump. I got my multi meter out and started testing fuse slots. Cant believe they didnt add more live spares.
theblet
I tapped into fuse F44 trailer ind light ? It works when truck is turned to mar . I dont have a trailer but there is a 10 amp fuse in the slot. So i put in an add a fuse, grill lights are working now. Heres a picture ,changed the grill and lights. Figured i would change the halogens since i had everything apart anyways lol.
Nicely done. I don’t have a trailer camera, I’ll have to check for a fuse as well
