Kingkeller50
- Jun 3, 2021
Is there anyway to install just a front camera on your 2021 bighorn ?
I hope someone answers soon... I had a 2015 without the sensors and was happy my new one did NOT have the front sensors, now I am not so sure. I cannot figure out where my front end is and have had to get back in and move it up a few times. AND since the thing is four inches longer than the 2015 it sticks out big time so, I have had to get in and move it forward a few times for that... I think they can stop now on making them bigger and longer.would this work? it literally plugs into the back of the 8.4 uconnect. I have the 12" uconnect so not sure if compatible. The video install looks legit...
Z Automotive Z-JL-Cam Front Camera Kit for 18-22 Jeep Wrangler JL
Approach the most advanced trail challenges or the curbing at the mall in full view with this clever plug and play front camera add on for your '18-'20 Jeep Wrangler JL with Z Automotive's Front Camera Kit Designed for Jeep's equipped with 8.www.quadratec.com
I need one too! Nearly ripped a tire at McDs drive thru the other night
Are you trying to wire one with a parking feature or just one when the vehicle is on? Either way I just did a fuse tap to the interior fuse box and the ground to a bolt near the fuse box.With an aftermarket front camera I have done everything. The only thing I have left is the 12v source power. I was told if you go to battery it will get hot. Has anyone done an aftermarket one and where are you pulling power from ? Maybe somewhere in the fuse box?
Just when on. Maybe that is what others were doing.Are you trying to wire one with a parking feature or just one when the vehicle is on? Either way I just did a fuse tap to the interior fuse box and the ground to a bolt near the fuse box.
That’s a good idea. Where did you find that?
I ordered this power adapter to plug in-line with the accessory power plug in the tray above the radio to power my front cam, just make sure you don’t have that accessory plug set to constant voltage, if you go this route.
Do you have the part number or link to it?The big e commerce site (ends with bay). It’s a 12 Volt Accessory Power + Ground T Plug Connection Cable for Some Jeep/Ram/Fiat. It was right around $20 shipped.
Where did you make the change from constant to keyed?
