275.55.20 vs 275.60.20
CogitoErgoLevo
Los Angeles
I have a cross country trip coming up (3k+ miles) mostly highway and i am about to replace my tires with Michelin defender ltx m/s2.
I am on the fence between 275/55/20 and 275/60/20.
Besides the size difference between the two, and that the 33s look a little better. Is there any advantage or disadvantage to go to 33" tire vs stock 32"?
I have tazerDT to recalibrate if needed.
Thanks
Ramroo
33s more meat (sidewall):
Better on road - pothole protection
Better off road - more sidewall for ruts, rocks, holes, slightly taller for ground clearance.
Looks a lot better
CogitoErgoLevo
Los Angeles
Thanks,
I'll get the 275/60/20 Michelin LTX M/S2. Coming from LT (E) rated tires for the past couple of years, I bet I will get a nice bump in mpg and quiet highway ride.
theblet
The mpg difference won’t be noticeable it it’s a 32” 4 ply tire going to a 33” 4 ply. It does looks better too
E.Hands
Youngsville, Louisiana, USA!
I went 275/60/20 years ago. And no regrets at all. My next set will be 275/60/20 Michelin LTX M/S2 too.
Michelin says that tire weighs only 39 pounds!
Which is far lighter than any other tire that I was considering in that size.
That and the fact that you are going one inch taller, I wouldn't be surprised if you gain a little MPG.
After calibration of course.
jkm312
If the truck is kept in a garage, check for door clearance. It most likely will, but it is worth checking on to cover all the bases.
CogitoErgoLevo
Los Angeles
I ended up going with Cooper Adventurer 275/60/20. They were $150 less per tire installed compared to the Michelin. $600 less for all 4 installed.
CogitoErgoLevo
Los Angeles
Calibration with TazerDT is super easy. I set the tire size to 33" and speedometer now matches waze. Before it was off by 1 or 2 mph depending on speed.
The default setting for my 32" tires was 32.18, in case anyone is curious
