CNC99
- Jul 7, 2022
As the title states I have a “tick.” I thought it was just the exhaust manifolds as they were cracked. While that did fix the obnoxious startup tick, this one has persisted. In any videos I have captured it is hard to hear clearly. But in person it is pretty easy to pickup. Even with my carven exhaust system screaming I can hear the tick walking up to it from the sides or sitting in the drive through with a wall to echo off of. Under the hood it is surprisingly not as noticeable as the injectors pulsing is the most prominent sound there. But slide under the truck and you can hear it no problem, I’ve more or less pin pointed it to under the truck right around the oil pan.
Any suggestions on other things to check. I kind of gave up tracking it down for awhile but I’m at 55k miles and if it is a lifter issue or a rod or another mechanical issue I’d like to get it addressed before my warranty is up. I’m no expert but from my general understanding usually ticks heard from up top are lifters and down low is a rod. Attached are a few videos I tried capturing, all 3 videos the truck is fully warmed up and has been driven for 30+ minutes at operating temperature. I wish the camera would pick it up how it is in person, but hopefully y’all are able to make it out over all the other noises.
