GruvenParts is proud to release METAL replacement gears for the 5th generation (2019+) Ram trucks power folding mirrors. Our metal gear is machined from 1 solid billet to include both the spur and worm gears machined into the main rotating shaft. We also provide these gears with new high strength Nylon stop rings which are usually needed when the OEM stop rings fail. These gears and stop rings carry GruvenParts LIFETIME WARRANTY!!
As many have come to find out, the OEM power fold mirror drive unit contains a plastic spur gear and stop ring which easily cracks, rendering the entire mirror useless. GruvenParts has solved this problem by creating an integral worm/spur main gear from solid, strong, UNBREAKABLE gear brass. We also provide a new Nylon stop ring which is much more durable than the brittle OEM stop ring to ensure the unit indexes to the proper outward position when commanded.
DON'T pay for an expensive replacement OEM mirror assembly with more cheap plastic gears and rings in it, and don't settle for aftermarket mirrors that also contain plastic gears.
UPGRADE, STRENGTHEN and IMPROVE your existing mirrors (SAVING MONEY AS WELL!)
One billet gear & stop ring will fix one mirror, 2 gears will fix both mirrors.
PLEASE NOTE: These gears & stop rings are side specific so order accordingly.
Applications :
2019+ (5th generation) RAM trucks with standard power folding mirrors including Bighorn, Laramie, Limited, Lone Star, Rebel, Special Service, Sport, and Tradesmen (all trim options) with 3.0L, 3.6L, or 5.7L (all motors). This gear does NOT work for the larger towing mirrors.
To purchase, click here:
GruvenParts Metal Power Folding Mirror Gears (5th Gen 2019+ Ram 1500 DT Trucks)
